Extend Wall Wraps at Inserts beyond wall centerline
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
jagostinho74
1895 Aufrufe, 9 Antworten
hello,
Is it possible to extend a Wall Wraps at Inserts beyond the wall's centerline?
Even using the Wall Closure method seems not to be working.
Asking for a friend :grinsendes_Gesicht_mit_lächelnden_Augen:
J
Assistant BIM/CAD Manager
Manchester, UK
Tags (3)
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: jagostinho74
Yes. Don't use "By Host". Use Family's Wall Closure Plane.  Works like a charm.
Nachricht 3 von 10
als Antwort auf: barthbradley
To clarify...
In the Family, pick Ref. Plane in Plan View and check the "Wall Closure".  Then in Family Types dialog box set "Wall Closure" Parameter to side(s) you want to wrap (e.g. "Exterior").
For this example, I placed the 'Wall Closure" Ref. Plane in Family @ Interior Face of Host Wall. Here's the Wrap condition in Project Plan View:
Nachricht 4 von 10
jagostinho74
I was trying the Wall Closure plane. But missing the step of switching from "By Host" to "Exterior".
As you said, works like a charm.
Thank you
J
Manchester, UK
Nachricht 5 von 10
tenak333
Hello!
Why do I get wrap only at one side of the door?
In door family, I marked both reference lines as wall closure.
Thank you in advance!
Nachricht 6 von 10
als Antwort auf: tenak333
@tenak333 wrote:
Hello!
Because you don't have any finish layer on the Interior side.  Core layers cannot wrap as you can see the box is greyed out.
Nachricht 7 von 10
tenak333
als Antwort auf: ToanDN
Here is screenshot with added finish layer.
I still don't have the wrap on the right side of the door.
Nachricht 8 von 10
Share your door family here.
Nachricht 9 von 10
tenak333
Here it is
Nachricht 10 von 10
ConstantinBudui
have the same problem. doesn't make sense that it only wrapps on the right side and not on the left. Both ref planes are checked as closure
