I need to have the finish wall layers on both sides of a wall to terminate above grade and the footing remain below grade. When I unlock the center core layer only however, the arrows appear for all the layers, and when I move any of them up, the footing moves with it. I've seen a post on this before but can't locate it. Any help is appreciated.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
What about just entering a value for the Wall's Base Extension Distance?
