Extend Layers at End Of Wall
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
PhilvK
671 Aufrufe, 14 Antworten
I've unlocked layers so the the wall finishes can extend to the base of the wall (orange arrows). How do I get the end of the wall highlighted in yellow to extend to the green line?
14 ANTWORTEN 14
Nachricht 2 von 15
vitorbortoncello
als Antwort auf: PhilvK
unlock it too
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 15
PhilvK
als Antwort auf: vitorbortoncello
I tried that but can't figure hew. Cutting a section thru the end of the wall doesn't show anything.
Nachricht 4 von 15
Does the wall originate from that lower level? If so, zero out the Base Extension values under the Wall's Instance Properties.
Nachricht 5 von 15
PhilvK
als Antwort auf: barthbradley
Yes, that works for the end, but then the sides don't work. I want the wall to set on a concrete curb and the tile extend to the floor on the sides and end of the wall as in the sketch below.
Nachricht 6 von 15
Ah, I see what you are doing now.  Offset the Wall from Level (offset=height of curb) and then enter the distance to drop the Base Extension.
Nachricht 7 von 15
PhilvK
Did that too, but that brings the end up also!
Nachricht 8 von 15
wait a minute. I think I  gave you the wrong instructions. Can you just post the file so I look at the Wall Assembly and see what's unlocked.
Nachricht 9 von 15
PhilvK
File attached. Thank you for looking!
Nachricht 10 von 15
Do not extend layers.  Lower the entire wall to the floor then join it with the concrete curb.
Nachricht 11 von 15
This?
Nachricht 12 von 15
PhilvK
als Antwort auf: ToanDN
Nice. Didn't know you could do that!
Nachricht 13 von 15
Ah! I just understood your construction. You're wrapping a curb/stem on the ends with the wall's finish layers.  So basically, the curb/stem is an embedded wall.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-68DB5265-BF43-45E3-AB8C-AC7813310548
...@ToanDN's a rock star as usual.  :zwinkerndes_Gesicht:
Nachricht 14 von 15
PhilvK
Embedding the curb appears to solve the end issue, but then the side layers can't be extended.
Nachricht 15 von 15
Create Parts from Wall, Select the Core Part in Section View, activate Shape Handles and then drag the base up to the top of the curb.
