Everytime I try to export revit database with DB link, revit crashes regardless the type of database i choose to export to ( excel, access, sql).
I did not have the same issue with a revit 2017 in my previous employer workingstation. I was wondering if this error is related to a software issue?
I found this problem it has been spotted in the past since it is present in an Autodesk troubleshooting matrix, but the link to its solution is not anymore.
Thank you for your help
Ive had the same problem in the past.
Have you tried following these steps?
I do know that getting the revit db link to work is tricky the first time.
Same for Revit 2022. Whenever I enable DB Link Revit crashes. Without any error message.
Your link @nmarcelis doesn't work anymore. Do you have any idea?
Dear @Stefan.Peckruhn
Recommend you reinstall Revit DBLink and Microsoft Access Database Engine 2016.
I share a link for version 2022.
https://www.mediafire.com/file/vjbzeoaovfgk8mt/Revit+2022+Data+Link.rar/file
Luck!
AutoCAD Certified Professional | Revit Certified Professional | 3Ds Max Certified Professional | Fusion Certified User | Autodesk Certified Instructor | VRay Certified Instructor
