Exporting to PDF - sheet not whole
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
PS224358
1699 Aufrufe, 7 Antworten
Good afternoon, I want to make this drawing in PDF but the result is not on the whole sheet. Can I figure out how to fix this?
Because the page is A1 it is not visible.
7 ANTWORTEN 7
Nachricht 2 von 8
oladamilola
als Antwort auf: PS224358
Have you cross-checked if your selected paper size corresponds with your Plansize?
And try putting the Paper placement option to "center".
Nachricht 3 von 8
Microsoft Print to PDF doesn't support A1 out of the box.  Try some other PDF printers, or if you use Revit 2022, try Export to PDF.
Nachricht 4 von 8
PS224358
als Antwort auf: oladamilola
If I can see then it is placed in the center.
Nachricht 5 von 8
PS224358
als Antwort auf: ToanDN
I'm trying to export it as a PDF, I can't choose another paper format like A0 or A1Naamloos.png
Nachricht 6 von 8
Yes because Microsoft Print to PDF printer does not support those paper sizes natively.  You could hack to add the missing paper sizes (google it), or just get a free PDF printer such as PDF Architect and you can create PDFs in A1, A0 and more.
Nachricht 7 von 8
PS224358
Thank you for your reactions. I must to download Revit 2021 to export the file in A1 of A0.
Nachricht 8 von 8
luisPDAN6
Just download Docuflow trial from the app store  https://apps.autodesk.com/RVT/en/Detail/Index?id=6842090281765127625&appLang=en&os=Win64
You get that done in 2 seconds for free without upgrading Revit.
