Exporting to NWC from Revit, keeps Exporting my 3D Views which i do not want
Aidan_HawkinsZZTBA
Message 1 of 11
Aidan_HawkinsZZTBA
Can someone please help me with this , I do not want to see my 3d views when i export to NWC in navisworks. I tried looking online and nothing. What do I do? I cant have all these little icons
Replies (10)
Message 2 of 11
hmunsell
3D views are kind of Navisworks wheelhouse. You can ADD 2d Sheet views and other models to a NWD/NWF, but the NWC is only 3D content.
https://help.autodesk.com/view/NAV/2025/ENU/?guid=GUID-4144E780-0018-4F92-BBF1-1710B8B52FCB
https://help.autodesk.com/view/NAV/2025/ENU/?guid=GUID-4059C73F-457F-45B3-BC26-62866352288E
Howard Munsell
Message 3 of 11
Aidan_HawkinsZZTBA
Thanks for this, Is there any setting I can turn off that when i open the NWC I do not see these icons?
Message 4 of 11
SteveKStafford
I export from Revit to NWC files frequently and I have never seen those icons. I do get saved viewpoints in folders from files that I append but I've never seen those before. What saved viewpoints are you seeing them in?
Steve Stafford
Message 5 of 11
Aidan_HawkinsZZTBA
I sent the revit file to a colleague and they dont have any problems either. My guess is now that it is a setting in navisworks that I have on that brings these up? surely the only reason
Message 6 of 11
RDAOU
@Aidan_HawkinsZZTBA
If I am not mistaken, those box icons you're seeing in your Navisworks export are artifacts that typically indicate unresolved or unsupported annotation symbols or 2D elements (like tags, symbols, or detail components) that were present in your Revit model but don't translate properly into the 3D Navisworks environment. Try the following see if it resolves the issue:
Use a dedicated 3D view made specifically for Navisworks export and Hide unnecessary categories via Visibility/Graphics (VG), specifically:
  • Annotation Categories
  • Analytical models
  • Work planes
  • Levels
  • Reference planes
 In the export settings
  • Set "Convert" to "Current View Only"
  • Disable or uncheck any "Convert linked files" or "Convert element properties" if not needed
And last but not least, check if there are any updates which need to be applied either to your Revit or the Exporter you are using
Message 7 of 11
hmunsell
as @SteveKStafford mentioned, I'm not sure what those icons are? cant say I have ever seen them in NWC i have made.  Typically, when i do an export from Revit, or import the RVT directly into Navis (which makes a NWC when you do that), i have the settings set to Entire Model. That brings in all the modeled elements and typically, no annotation comes in.
as @RDAOU mentioned, set your export settings to a dedicated 3D view that is cleaned up to only what you need, and pick the "Current View" option. i often just pick the Entire Project option.
Howard Munsell
Message 8 of 11
hmunsell
can you upload the NWC for us to look at?
Howard Munsell
Message 9 of 11
mari.shimode
Hi @Aidan_HawkinsZZTBA, how are you doing? Please reply if you still need assistance. If you have solved the issue, please click the Accept Solution button so that others who have the same question can find the information easily. Thank you.
Mari Shimode
Message 10 of 11
Austin.HessAT24T
Observer
Observer
I believe these icons are representative of a 3D view's camera. These icons are only visible when you have Links turned on inside Navisworks. When exporting to a .NWC, that .NWC houses a 3D View folder with all of the Revit files 3D views as Saved Viewpoints. I've tried turning these off by toggling different settings and I can't find any solution either, which is why I'm here.
I believe your colleague did not have Links active in their own Navisworks.
Message 11 of 11
devashish7
Those "little icons" are most likely Revit Saved Views being exported into the NWC. To prevent them from appearing:
  1. In Revit, go to File > Export > NWC.
  2. Click Navisworks Settings.
  3. Uncheck Convert Linked CAD Formats (if not needed).
  4. Most importantly, check whether Export Rooms, Areas, and Views options are enabled and disable any view-related exports you don't need.
  5. Re-export the NWC and reload it in Navisworks.
If the views are already in Navisworks:
  • Open the Selection Tree
  • Expand the Revit file
  • Look for the Views folder
  • You can hide or remove them from the NWF, but they will return if they continue to be exported from Revit.
Can you post a screenshot of the icons you're referring to? If they're appearing in the Selection Tree, Scene View, or Saved Viewpoints panel, the solution is slightly different.
