Exporting to Ifc
Exporting to Ifc
ymakJ492S
Exporting to Ifc
ymakJ492S
I open an Ifc file in Revit and export it twice as Ifc.
My issue is that for certain elements, e.g. IfcDoors, the element IfcGlobalId I get differs in each exported Ifc file.
Shouldn't it be the same and equal to the IfcGuid I see in Revit?
ymakJ492S
I have tried it and it hasn't worked.
When I open the Ifc in Revit I can see in the IfcGUID the value that exists in the original Ifc file.
I export it as you suggested and I cannot find in the exported Ifc file the IfcGUID value that exists in the Revit file.
Any explanation?
RDAOU
@ymakJ492S
IfcGUID should not change..See below GIF and the settings used in the standard OOTB exporter
  • use Link and Export instead of Open and Export
  • Export Links as separate IFC
  • make sure the option to store ifcGUID to a parameter is checked
ymakJ492S
Thank you.
