Exporting to IFC from Revit 2016, problem with floors
Message 1 of 8
I am designing a multifloor parking structure with sloping floors. When exporting this to IFC, all the sloped floors are exported to a wrong level actually some meters under the structure, all to the same level. What can I do? I have installed SP2.
Anssi
Replies (7)
Message 2 of 8
Are there any solutions? I attach an example file and IFC
This is how it looks in Revit and IFC:
Message 3 of 8
GHASEM_ARIYANI
hi
Does the material have applied for elements??
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Message 4 of 8
In my example everything is a standard concrete structure. What would material have to do with it? To me, what seems to happen is that the exporter has a bug where the split lines and heights that in Revit are relative are transformed into absolute heights in the export.
Anssi
Message 5 of 8
Looking still further into this, I discovered that simple rectangular floors that have an edge or a corner set to a different elevation export correctly, but floors with split lines or nonrectangular floors with a corner set to a different elevation have the error as described in my earlier posts.
Installing the 2016 R2 version doesn't help.
Anssi
Message 6 of 8
I have the same problem. Did you find any solution?
Sanna
Message 7 of 8
GHASEM_ARIYANI
Hello
Yes
export Without material .
Message 8 of 8
How do I do that?
