Exporting to DXF
1 ANTWORT 1
Nachricht 1 von 2
manuel_roldn-pardo
170 Aufrufe, 1 Antwort
Exporting to DXF
Hi everybody,
I hope you´re all well.
I am a new Revit user and looking for advise on the best way of getting a dxf file from a Revit model provided by a client, being able to do the following:
1. Select elements to be exported
2. Group elements in new layers. Let say I want to add all types of walls and colums to a layer called Vertical elements.
3. Export a dxf.
Is that possible creating a plug-in or its something that can be done in a diferrent way.
Thanks in advance.
Beschriftungen (2)
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: manuel_roldn-pardo
@manuel_roldn-pardo wrote:
Hi everybody,
Create views and set them to show only elements you want to export.  Then export those view.
Change layer assignment under DWG Export options.
3. Export a dxf.
Choose DXF format when export to DWG.
Thanks in advance.
