Exporting to DWG Where does the layer info come from in the families?
7 ANTWORTEN 7
Nachricht 1 von 8
682 Aufrufe, 7 Antworten
Hi all, Does anyone know where REVIT pulls the layer naming from in the export tab. I have an image I a sharing. I want to control the names before they get to export.
7 ANTWORTEN 7
Nachricht 2 von 8
RobDraw
als Antwort auf: Anonymous
Rob
Nachricht 3 von 8
als Antwort auf: RobDraw
Is there a place in the model that I can control it?
Nachricht 4 von 8
RobDraw
The export settings is where you control them. Not really sure what you are asking.
Rob
Nachricht 5 von 8
In the export dialogue box.
Nachricht 6 von 8
I think I am explaining this wrong.
When I build a family I can create subcategories. By default Hidden Lines in already in the subcategory creation pop up window. Hidden Lines in the layer column has a unique name separating it from the other assets in the same category.
When you run the export and click to activate the (Modify DWG/DXF Export Setup) you can see all assets in the model and see the data that REVIT pulls.
If I expand Electrical Equipment it will show me all the families and Subcategories I created in the families.
Next, to that is the layers field I want to know how to control the naming convention before it ever gets to export so that I do not have to do it at export.
This has to be controlled from inside the family it's self, parameter, or some master set I just need to know where this information is stored.
REVIT DEV team feel free to jump in on this one.
Nachricht 7 von 8
can that be modified? or can I add to it?
Nachricht 8 von 8
RobDraw
Of course.
Rob
