When it's time to export the floor plans I set up a new sheet with all the view i want to export cause i need a single dwg file with all the floor plans on a single file.
(cause Revit is set to name blocks with a progressive system and merge single dwgs after export it's a mess).
Is There a way to have the floors in model space to the same distance from eachother??
Trying to explain; assuming the project point is set in a good way, during the export it will be on 0,0 on the first one we insert in the sheet so we would have:
- ground floor on 0,0
- first floor on 0,15000
- second floor on 0,30000
and so on.
Is there a way to set this up directly in REVIT and reduce the Autocad work having a "ready to go" DWG file always in the same place?
