When I export my Demo plan, demo rcp, and new floor plan, all of the demolished and new come in as blocks (which is fine) but have black color layer. I have to go into each individual block and the layer is Color 250 and I have to change it to be 'By Layer' and save. Does anyone know where within the export settings I can change this so I don't have to go block by block to change the layer color?
I saw in a different forum you settings of hitting the three ... in the first window when exporting but not sure within that dialog box I can change it to have these blocks not showing up as black lines after i export,
Gelöst! Gehe zur Lösung
Gelöst von spowers. Gehe zur Lösung
When you choose export, did you choose the Export all properties bylayer but do not export overrides?
That option made everything its own layer and did not distinct what would be getting demolished or now. I did keep it on the 'Export category properties BYLAYER and overrides BYENTITY', went 'Add/Edit Modifiers for All...' and added the {Phase Status} to Modifiers added. This seem to change everything that was being demo'd to a white layer instead of the black that I was having a problem with.
