I'm trying to export schedule to excel using DBLINK but the tabs under MS Access 2007 and 2000-2003 are empty. Only ODBC able to selection connection.
Pls advise as I am using Microsoft Excel to edit scedule and then link back to Revit 2017.
Title edit for clarity: Exporting schedule to excel using DBLINK
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
If I remember correctly you need Excel 2010 64 bit as the minimum. That was with the last time I used dblink in Revit 2015.
By the way, you don't export just schedules via dblink, but the entire model data. If you only look for a two way export edit import schedules, I would look into Dynamo.
Thanks Toan for the info.
I definitely wont need to export entire project data, only one schedule but I am not familiar with Dynamo, dont know which boxes required to link to....sigh.
I'm using Microsoft Offcie 2016, but I cant select connection to export, not to talk about import.
Any solution?
Not sure what else to suggest. I have Access 2010 64-bit and DB Link with the option of export to MS Access 2007 works in Revit 2015-2017.
I'm having the same problem, the MS Access tabs are empty. Do I need to set up a ODBC first? I'm running Revit 2017 and Access 2016.
Hi @Magnus.B
Please see the articles below:
Forum post HERE
Let me know if this helps!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @Anonymous
Here is the video on how to Export and Import Revit Data to Excel using Dynamo
Viveka CD
Hi @Anonymous, @Magnus.B
Just checking in to see if you resolved the issue or you seek more assistance from the community.
Let me know and I look forward to your reply.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Viveka CD
@Viveka_CD Hi thanks for following up, my organization refuses to use office x64. and as of my understanding Revit 64 bit cannot talk to x86 Access.
Hi @Magnus.B
Yes, looks like it.
If Access 2007 x86 is installed on x64 machine, the driver cannot be installed.
Refer to the table HERE for more information.
Viveka CD
For now, I have marked solutions to few workarounds to benefit the community!
If you have additional questions, we can continue this thread.
Viveka CD
Hi, i may have missed it but i dont see a solution for the original question. So maybe this will help as i experienced this today. I have ticked all the boxes;
Access x64 (doesnt matter if you install from 0ffice 365 or access standalone.)
All i did was download and install the AccessDatabaseEngine_X64.exe (https://download.microsoft.com/download/2/4/3/24375141-E08D-4803-AB0E-10F2E3A07AAA/AccessDatabaseEng...)
And it gave me the the [Select a new connection] from the MS Access 2007] tab.
