Hi there,
I am running into a problem.. and this has been annoying me for long
When I export my revit project to pdf (for print), it just appended/populated to the end of my old version of exported pdf file instead of creating a new file or replacing that old file.
So that is, every time I publish a work, there is only one pdf file, increasing its page number..
is there a way to resolve this problem?
The images attached show the export setting I have:
thanks in advance,
Andy
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
have you try to use another printer driver like BULLZIP and see if any issues. thanks
Check the Bluebeam setting. This is what I have.
Hi Andy
We came across with a lot of issues using Bluebeam. So i totally understand your frustration with that and other issues. To start Bluebeam it does not auto-configure paper size and orientation completely and it is very slow. Than has a lot of meaningless configuration options that just creates obstacles instead of helping. Its is no surprise because that is developed by a competitor of Autodesk (Nemetschek). I think you will get a much more reliable production of PDFs using the apps that are in the Autodesk App Store. We recommend using the app from the page: https://apps.autodesk.com/RVT/en/Detail/Index?id=6842090281765127625&appLang=en&os=Win64
hi @syman2000
thanks for the reply
How do I go to open up the "Bluebeam PDF property" and the save as setting (as per your screenshots)?
we are using Revit --> Print --> print options..but could not find the same panel as you got
Which version of bluebeam are you using? Should be in your windows setting>printer and configure your Bluebeam
Hi @luisPDAN6 thank you for your reply.
That add-in driver seems to cost so we would try to resolve the way using Bluebeam for now ![]()
Great to hear. Make sure you mark this as resolved so people who have the same issue will point toward your post.
