exporting Revit to DWG
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
756 Aufrufe, 8 Antworten
8 ANTWORTEN 8
Nachricht 2 von 9
zemeraloni
als Antwort auf: Anonymous
Hi @Anonymous
This is a normal dwg export of 3d view.
What did you expacted to get?
Nachricht 3 von 9
als Antwort auf: zemeraloni
hi ,  no it's not a normal 3D export if u look closely it look's like  transparency model !! 1.JPG
Nachricht 4 von 9
-FDC-
Did you try the Autocad command "shademode" ?
Nachricht 5 von 9
als Antwort auf: -FDC-
thank u so much problem fixed
Nachricht 6 von 9
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk Community! I see that you are visiting as a new memberSmiley (fröhlich)
Which version of Revit are you using?
Do you mean that the orientation of the dwg is not what you expected when you import?
Looking forward to your reply.
Nachricht 7 von 9
Viveka_CD
Glad to hear that!Smiley (fröhlich)
Let us know if you have additional questions and make sure you have the latest updates installed for your Revit version.
To make sure that the issue you are seeing is not something already fixed in one of the product updates, I would suggest checking the Desktop App to see if there are any Revit updates available. For information on using the Desktop App see the following article: About the Autodesk Desktop App
Note: If you are not able to download updates through the Desktop App, the following article has information on downloading updates through the Autodesk Accounts page:
Install Updates, Add-ons, and Enhancements
Nachricht 8 von 9
als Antwort auf: Viveka_CD
thank you . yes i'm new here i'm using Revit 2016
Nachricht 9 von 9
Viveka_CD
@Anonymous
No problem. Please post on the forums whenever you have a question with Revit and its tools.
Glad to help!
