Exporting Revit to CAD - Layers
3 ANTWORTEN 3
Nachricht 1 von 4
kamaluddin.shaikh9
203 Aufrufe, 3 Antworten
Iam facing a problem during exporting Revit plan into cad
The problem is.
When I export a Revit file in cad
All text leaders and arrows are exploded
Is there any solution to resolve it.
3 ANTWORTEN 3
Nachricht 2 von 4
Avaris.
als Antwort auf: kamaluddin.shaikh9
It is, the way it is. It is possible to export to AutoCAD, but in most cases not recommended.
You could try the overkill command in AutoCAD. Hopefully, that solves most of your issues.
Nachricht 3 von 4
Corsten.Au
Hi
you need to resolve it in the settings while exporting to CAD..
check these settings..
Text CADText CAD
Corsten
Building Designer
Nachricht 4 von 4
ennujozlagam
hello, this is known issue but until now no solution yet from autodesk. thanks
