Exporting Revit to CAD layer modifiers phase stat for Demo, New, Existing layers
Message 1 of 16
Are there any tutorials that explain how to export Revit files to CAD using modifiers 'phase status' so that demolished doors and walls show up as a demo layer?
Replies (15)
Message 2 of 16
Message 3 of 16
That's how I set it up but it is still not dividing the wall/door layers up into demo and new.
Does it matter what view I am in?
How should the phase and phasing filter in the view properties be set?
Message 4 of 16
Is this correct? or does demo have to be written out?
Message 5 of 16
You screenshot looks wrong for am Existing view.
Existing views:
- Phase = Existing
- Phase Filter = Show All
or
- Phase - New Construction
- Phase Filter = Show previous
Demolition views:
- Phase = New Construction
- Phase Filter = Show previous + Demo
New Construction views
- Phase Filter = Show previous + New
Most importantly, your objects must be assigned with correct Phase Created and Phase Demolished values.
Message 6 of 16
Does it matter which view I am in when I export?
Message 7 of 16
The way I have it set up is the only way I can see both the demo and new in the same view... maybe the drawing is made incorrectly.  It's from another company.
Message 8 of 16
If you want the CAD Layers say demo then you need to spell it out. Normally D is enough.
Message 9 of 16
Attached are the Revit 2016 and the exported CAD files.
Message 10 of 16
No. You can open any view and export multiple views at one scoop.
Message 11 of 16
Still not working.
Now its not even bringing in demo objects....
Ive attached the file.
Message 12 of 16
I am not getting any demo or new layers even though the layer modifier has phase status set.
If it doesn't matter which view I am in... why am I not getting any demo objects in the cad file?
Message 13 of 16
I exported you A1-00 sheet to DWg just fine.  That is the plan showing the existing and demolition stuff.  The one you show is the New Construction plan (even it was labeled as Existing), thus demolition elements do not show.
Message 14 of 16
Isn't there a way to export all the phases together as one autocad file with new doors and demo doors on different layers?
Can I export to one dwg. with existing, new and demo doors/walls all in one file?
Message 15 of 16
Because the Phasing configuration of your project is fundamentally wrong.  There is no Demo phase in Revit.  Demolition is an action happen in New Construction phase.
The way your project is setup, you need to show all 3 phases in a single drawing and Revit cannot do that.  You can either fix the Phase setting to only have 2 phases: Existing and Demolition, and change all the demolished elements to be created under Existing Phase and to be demolished under New Construction phase.  Or, you would have to export at least two CAD files and combine them in AutoCAD.
Message 16 of 16
David125
This isn't working for me either, I have 2 phases existing and demolished.
