AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Exporting revit model to sketchup or rhino with textures
2 ANTWORTEN 2
Nachricht 1 von 3
akaz.warman
2795 Aufrufe, 2 Antworten
Is there a way to export Revit  geometry to rhino or sketchup with the texture data to make renders ?, Why is this  not possible ? or even vice versa without having to go through the trouble of assigning materials through object styles. For a small project this is feasible but for large projects its tedious and time conusming. What is the most efficient way to do this ?
Revit should incorporate the feature to export material along with geometry between different softwares.
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: akaz.warman
@akaz.warman
  • Instead of DWG/DXF, if you export from Revit as .FBX or .SAT, material should carry over
  • There are already plugins which provide this interoperability between Rhino and Revit...check the Rhino website or companies such as Evolvelab and Provinggrounds.
To answer the "when" question...Most of such creators collaborate with Autodesk at different levels and in my personal opinion I doubt it is or will ever be in Autodesk's strategy to kill such businesses by replicating the plugins/codes which those firms have created. At one point in time Autodesk might consider to fairly acquire a plugin (which they have done in the past)  but not replicating it....Revit itself was acquired from the original developers
Nachricht 3 von 3
syman2000
You should check out Conveyor plugin by proving ground. It allows bi-directional Revit to Rhino and vice versa. As well material set in Revit will remap in Rhino with material.
https://apps.provingground.io/docs/conveyor-documentation/product-overview/
For Sketchup, there are numerous plugin. You can check this forum for links to the plugin
Revit to Sketchup WITH MATERIALS - Revit Forum
In Foren verƶffentlichen
