When following the instructions to export from Revit LT 2019 to SketchUp Pro 2018 I am getting a warning - Import Fail! in SketchUp. Any suggestions out there?? Thanks in advance! : )
Thanks for this recommendation. Do I need to download Revit LT 2013 in order to save the file or how do I save my 2019 file to 2013 or 2010?
Thanks so much!
No
Thanks so much!
You are exporting as a DWG right? Just save as 2013 DWG format when you specify the file name, just below that you can change the Files of type...select 2013 dwg.
