Exporting revit file from Revit 2017 to IFC
1 ANTWORT 1
Nachricht 1 von 2
361 Aufrufe, 1 Antwort
So far i was working on Revit 2015, and sometimes i saw that after exporting file to .ifc some informations were missing (some elements were gone from model). I am starting to participate in a new project in Revit 2017, and i would be glad to know how much this file exporting is improved in comparison with Revit 2015?
Cheers
RN
1 ANTWORT 1
Nachricht 2 von 2
pipapongo0909
als Antwort auf: Anonymous
The IFC Exporter Plugin has been integrated so it much more adaptable.
First configure your mapping table: Revit Category - IFC Class by: Revit--> Export--> Options --> IFC Options
Consider this list since Revit does not support all IFC Classes
Sometimes this does not work or if you have nested families where individual parts need to be exported into different classes you can use the IfcExportAs Parameter:
Create a shared Parameter as Text and name it "IfcExportAs" and group it under IFC Parameters. you can set it up as type or as Instance, depending your needs.
I prefer to use "Type" so i put in the IFC Class directely inside the family and the users do not have to worry about it.
Does this help? If you have questions, let me know.
good luck
Jeff Wurth
BIM Manager | Dipl Ing. Bauingenieur
LinkedIn
