Exporting Revit Families
I have a file which I am wanting to export all the Autodesk Revit families out of.
For some reason when I try to file export the families tab is greyed out.
can anyone help me in working out how to fix this?
I have a file which i was wanting to export all the revit families out of. for some reason when i o to file export the families tab is greyed out.
Many thanks,
https://www.dropbox.com/s/xnq6efgvk1zuisk/mitchell%20detached.rvt?dl=0
Many thanks,
dferreira-blackwell
CAN YOU TRY SAVE AS-->LIBRARY-->FAMILY
sash.kazeminejad
Hi Mitchell,
To accomplish this task, go to your project browser and look for the Families Category. You will then see all of your family categories and families underneath the Families. Right-Click atop the name Families and click Save. Once you do that, you will be prompted to select a save location. Once you do that, the families will start exporting.
Hope this helps.
Sash
ebtDRCPD
Observer
Observer
Worked perfectly.  Thank you.
