I might be missing the point. But if it is not directly possible from within Revit itself then the only logical way is to access it through an API?
You could export data from Revit with something like Dynamo and store the information in a different format (e.g. txt file). You could use DB link to export data to a database.
Louis
Please mention Revit version, especially when uploading Revit files.
