Exporting render with transparent background - REVIT 2018
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1036 Aufrufe, 3 Antworten
This might be a daft question with a simple answer but I don't seem to be able to save an elevation or plan with a transparent background for importing into other software.  PNG files still have a white background and I cannot see anywhere that gives me the option.  Background setting choices are only Non, Sky, Gradient or Image.
Hope this can be done easily!
Using Revit 2019.
Ta
3 ANTWORTEN 3
Nachricht 2 von 4
cbcarch
als Antwort auf: Anonymous
Title of post says 2018, but you say you are using 2019. Should not make any difference, as far as I know.
From Revit Help:
To specify a transparent background
  1. In the Rendering dialog, under Background, for Style, select Transparent.
    If you export the rendered image to PNG or TIFF format, the alpha channel preserves the transparent background.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 4
als Antwort auf: cbcarch
oops about the title, not sure why I wrote that.  Anyway, thanks for your answer but in elevation and plans there is no render option.  I am wanting to export the plans and elevations and put them into other software that has various different coloured backgrounds and patterns.
Nachricht 4 von 4
This question hasn't been solved its just that the title is wrong from when I originally entered it as it picked up a previous tag/message.  Sorry
