I am having an issue exporting a plan perspective view to a DWG file. I placed the view on a sheet before exporting. When export the view, the DWG file opens with a very strange distortion. I used the same workflow to export a section perspective from the same project, and did not experience any issues.
The plan perspective was created by cutting a section then taking a camera view from above looking straight down.
How did you create your plan perspective view? Did you also export a sheet?
I prefer working in model space. Either way, it shows up the same in paper as model
