Hey all!
I use Revit LT 2021. I produce contract documents for my job. I am having trouble exporting them as PDFs to scale. My PDFs export to a paper size of 8.5" x 11" and I need them to be 24" x 36". I do not have the option under "properties" to select that size, so my question could also be posed as, how do I create a option to print "Microsoft to PDF" to a sheet size of 24x36? My drawings are all placed on sheets that size.
How do I do this? -- Thank you!
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
It could be your PDF driver. It may not have a paper size set up for what you want.
Microsoft to PDF cannot change size. You want to install
CutePDF - https://www.cutepdf.com/index.htm
Bullzip - https://www.bullzip.com/
PDFForge - https://www.pdfforge.org/
