I wanted to export a sheet as PDF from Revit 2024.2 and I am getting a yellow colour in the PDF that non existing in the active sheet view in Revit.
Revit Sheet View:
Exported PDF view:
I am expecting Revit should export it as is but there is a yellow colour in the PDF. I am aware that I can export a grayscale or black line version of it, but I have never experienced a discrepancy like this.
I have linked architectural Revit model within my structural model and I set it to host view from display settings.
I am using this Revit link as underlay with no overrides.
Is there a way to export PDF exactly like in the Revit active sheet view?
I am using Revit built in pdf exporter with following settings:
I have other linked views that can be exported as is without colour discrepancies in the same project.
Kindly provide input if possible.
Gelöst! Gehe zur Lösung
Gelöst von vitorbortoncello. Gehe zur Lösung
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
