Exporting Parameters to DWF
3 ANTWORTEN 3
Nachricht 1 von 4
361 Aufrufe, 3 Antworten
In 3D DWF exports, tha layer standard available are...
A. Texture
B. Line weight
C. Line pattern
D. All the above
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
https://helpcenter.graphisoft.com/tips/collaboration/dwg/dxf-dwg-translator-settings/
Nachricht 3 von 4
als Antwort auf: barthbradley
Nachricht 4 von 4
...actually, of all the questions you've posted on the forum today; this one is the most perplexing.  The way I read it, there is no correct answer listed for it.  Are you sure "All of the Above" doesn't actually read "NONE of the above"?  The question is about Layer STANDARDS (e.g. American Institute of Architects (AIA), ISO standard 13567, Singapore standard 83, British standard 1192).
