Exporting only selected shared parameters
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
adamskaEXHPY
571 Aufrufe, 2 Antworten
Hello there,
I am wondering if there is a way to export only selected Shared Parameters to be sent to subcontractor.
We have a ton of parameters and there is no need to share all of them - I believe it would be easier for the subcon to receive just selected 10 which they need in title blocks.
Would it work if I manually deleted the parameters they don't need from the .txt file?
Thanks!
Beschriftungen (3)
2 ANTWORTEN 2
Nachricht 2 von 3
SRushmoreLDG
als Antwort auf: adamskaEXHPY
I would highly recommend NOT manually editing the TXT file. You could create a new shared parameter TXT file and export those 10 parameters to it or you could use an add-in such as DiRoots' Paramanager or similar to export selected parameters to a new shared parameter TXT file. DiRoots' add-in is free :leicht_lächelndes_Gesicht:
https://diroots.com/revit-plugins/manage-revit-parameters-in-projects-and-families-with-paramanager/
Please click the Accept Solution button if my reply answers your question.
LinkedIn: steven-rushmore
Steven Rushmore
Corporate BIM/CAD Manager
Larson Design Group
Nachricht 3 von 3
adamskaEXHPY
als Antwort auf: SRushmoreLDG
Thank you. I am using DiRoots but for some reason it didn't cross my mind to use it for this particular issue... :zwinkerndes_Gesicht:
