Are you able to export an IFC in revit with only certain areas selected in the project. When i make the ifc, everything seems to be coming in.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
For selection: Select objects and make a Group, save Group to a new File, export that file to IFC.
For categories: Go to IFC Export Options and change categories you don't want to "Not Exported".
No,Its not possible.
as if I am exporting a 3D view of a particular floor & I have Cropped the floor in 3D view & the walls & other elements are associated with Bottom most & top most level so its impossible to export the IFC of that view.
