Exporting IFC from Revit: Walls don't attach to roof
0 ANTWORTEN 0
Nachricht 1 von 1
270 Aufrufe, 0 Antworten
Hi everyone,
I am trying to export an IFC from a Revit model including four curved walls and a sloped roof. All the walls attached completely fine to the sloped roof in Revit but:
  1. As soon as I export the Revit file as IFC and open it in Solibri, the wall becomes unattached to the roof or at least it looks like they are unattached. (image 01)
  2. The roof’s corners where I have slop arrow do not show, as they should. (image 02)
I have tried same IFC file in Navisworks and I have the same issue with same IFC file there as well. However, it works completely fine when I export a NWC from the same Revit file (Image 03)
I have tried to use Void Form to cut the upper part of the wall, which did not help either.
I assume it should be the IFC settings; I have tried different settings, unfortunately I could not find anything to fix the problem.
I was hoping that I could get some tips or suggestion here. Any help would be very appreciated Smiley (fröhlich)
Tags (3)
0 ANTWORTEN 0
