Exporting from REVIT to DWG issue
uoliveira
uoliveira
I have text notes with different sizes, for instance: Arial 2mm, Arial 3mm and i want export each one to diffrent layers  (.dwg). I saw that Revit has only one possible for exporting text notes. Someone knows how can i figure out this problem, maybe using Dynamo? Thanks in advance!
uoliveira
I have other problem about export's option. My linetypes keep solid, when i open in Autocad with "no overrides" export option. When I set "by entity" all the line types are ok, but my text notes come as layer 0, not layer 2, as it should be. The first image shows the option "by entity" and the second shows the "no overrides"
Alfredo_Medina
In my opinion, it would be easier to do that classification of certain text sizes in certain layers after exporting, directly in AutoCAD.
