Please explain in steps as 1, 2 ,3 how can I export and save current views of floor plans and elevations to be able to save as PDF and JPG files in order to share when needed. Because all I could find Is how to export CAD format files.
Thank you !
Gelöst! Gehe zur Lösung
Gelöst von aleksandr.b. Gehe zur Lösung
Sorry, nothing happened. No window opens where I can choose where to save my image (current view)
Also it is JPG only option. I need to know how can I save it as PDF too.
I got it. But I also need PDF format. How can I save it or print to PDF ?
NOT working at all when I tried many times ! I did it all in steps you showed but I am getting empty file PDF with setting ''fit to page'' and corner visible only with setting ''100% zoom size'' and sometimes ''Nothing to see here". Also it asks "do you want to replace current file ?'' If I say YES it replace it with empty or corner visible and if I say NO it does nothing. So if I want not to replace file but create new one how can I do that ? What am I doing wrong here ?
I do not know how to do screen share so you could see what is on my screen ?
Maybe I should change something with size where it says ''letter, A4, A5'' ?
