Exporting Design Options
2 ANTWORTEN 2
Nachricht 1 von 3
dwhitingRBKY9
557 Aufrufe, 2 Antworten
Is there a way of exporting multiple design options from the same options set into one 2D floor plan or 3D model that can be turned on and off in unique combinations just as they can in the model with Viz/Graphics? For instance, if I am exporting to DWF or DWG for a floor plan, can I get the design options on unique layers to toggle them?
I'm essentially trying to get around exporting each design option individually and creating a composite file which is very time intensive.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: dwhitingRBKY9
Create a view for each design option, place them on sheet aligned, export the sheet.
Nachricht 3 von 3
dwhitingRBKY9
als Antwort auf: ToanDN
@ToanDN Thanks for the reply. I don't think that will work for a couple reasons:
  • It is very time intensive to create unique views for all design options.
  • I would still need to create a composite plan later with some manual overlaying.
However, by creating the composite plan manually, I can control the layers that each design option is on for easy toggling later. Any other ideas?
