Exporting a view without rendering
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
1447 Aufrufe, 3 Antworten
Hi. i want to export a view , without rendering it . I've tried this method :
Right clicking on the view , selecting "Save to project as image" and then from "Renderings" node , exporting it as png file.
But the output quality is so poor. ( When i use PrtScr button and make screen shot from the view the result is way better )
is there a way to export the view with acceptable quality ? and also i need it to be transparent .
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
How about This?
You need to change the pixel value.
Nachricht 3 von 4
d.avalishvili
i recomment to print using pdf. hight quality. :leicht_lächelndes_Gesicht:
Nachricht 4 von 4
You can put that view in a sheet as it is and print it to PDF with a high quality.
Then open it in Photoshop. It has a transparent background.
