Exported revit model to IFC is not correct when opened in Navisworks Manage
1 ANTWORT 1
Nachricht 1 von 2
daan.kennis
290 Aufrufe, 1 Antwort
When i export my bearing walls and beams to IFC from Revit and open the exported IFC file in Navisworks. They aren't the same.
The way it is modelled in Revit is as following: Bearing walls are constrained to the underside of the bearing floor that's above the wall. Beams are joined to the bearing walls and floors so that the floor and walls are "cut" where the beams is at. (Picture 1).
When opened in Navisworks the mid wall is stopping to early and the walls on the corner are not joining properly like they did in Revit. (Picture 2).
Same happens when opened in Solibri. But when i open the Revit file directly into Navisworks it's done properly as shown in the Revit model.
Anyone knows what it causing this problem? I've tried unjoining the beams and cutting the walls by using Edit Profile but this doesn't solve the problem either.
1 ANTWORT 1
Nachricht 2 von 2
daan.kennis
als Antwort auf: daan.kennis
I don't know why but for some reason if i export as IFC4 instead of IFC2x3 the model in Navisworks is shown as modelled in Revit.
So problem solved.
