I found out that i can create objects faster in Sketchup, so i export my objects as IFC from Sketchup to Revit 2024 and after placment i export IFC. the result is correct but colors are missing. any ideas on how to fix this?
If your desired output is IFC and you are creating an IFC to go into Revit to then create another IFC, why bother with the Revit part? You have your object created in Sketchup and you have created an IFC.
If you need a better IFC output from Revit create the object in Revit.
I don't use Sketchup so not sure but would think a lot of data is being lost as you might have too many steps in your workflow.
You could also try this method>
To incorporate a SketchUp design, import the SKP file into a Revit family. Then load the family into a Revit project.
Then you can create the IFC out of Revit.
