Hi all,
I've been trying to build my portfolio (I'm a student) and keep running into this issue when I try to export images. I place the camera in the floor plan, check out the 3D image to make sure it looks the way I want, and export it to JPEG. However, the resulting JPEG image is often really blurry, the edges of the building have thick black lines, and it just doesn't look sharp and professional the way I want it to. What are the ideal export settings (pixels, etc) to make my images export correctly?
I've attached 2 files to show the end result I've been getting.
Solved by L.Maas. Go to Solution.
Solved by aRcHiTeCt.JM. Go to Solution.
.... hi @hilam91
... you need to tweak the setting for exporting an image
... play with these setting until you find your perfect set up
.... to get a better definition image
.... also you need to tweak as well these graphic display options
... to soften your image
.... to get better results
... also you can check the scale of the image...
.... another way is to render the images
... it will get way better results
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Make sure you have a proper scale set
The larger the values, the lines will appear thinner
Further you can adjust your export settings changing to png and setting the dpi to higher values might help.
Louis
Please mention Revit version, especially when uploading Revit files.
