exported geometry in to Revit- Not showing
info
Message 1 of 21
info
HI,
I created curved geometry in Solidworks and exported it as a .rfa file,
But I'm unable to see it as a family? I've attached a image of what it looks like.
it's approx. 31500 mm in length & 50mm thick.
Replies (20)
Message 2 of 21
Try Solidworks to DWG to Revit.
Message 3 of 21
Export to SAT file and import it in a family.
Message 4 of 21
info
Hi barthbradley,
Although SolidWorks can export in variety of 3D formats,
I can't export a model as a 3D .DWG, it only gives me 2D snap-shot/view of the Model.
I'll try the SAT.
Message 5 of 21
@info wrote:
Hi barthbradley,
I'll try the SAT.
Huh? I don't know what you are talking about, but there are many, many videos on-line - found through a simple keyword search - that will guide you through the process of converting Solidworks to DWG.  Check 'em out.
Message 6 of 21
info
this is what i get when saving from SW
Message 7 of 21
info
I tried importing a SAT, it didn't work.
Just iterate my last post;
I meant to say - I can export a DWG, but it's only a 2D "projection" if you like, from a particular view. Not a complete 3D model.
I did see a video of converting to a Parasoild first then importing into Autocad and saving as a DWG, but I don't have 3D Autocad.
I've attached an image- can this geometry be created in Revit?
Message 8 of 21
Importing a SAT didn't work how?  Can you be more specific?
Message 9 of 21
info
When I save the SW model to .SAT format, I get the following error, please see attached.
I've also included the .SAT file.
Also,  I'm opening the .SAT inside a project file through;
--> INSET TAB
     ---> IMPORT CAD
Thanks.
Message 10 of 21
info
.SAT
Message 11 of 21
The SAT file cannot be open obviously since you exported it with errors.  Why don't you share the SW file here?
Message 12 of 21
info
I can -I just assumed most Revit users would not have SW.
I also, like to note  this not the final shape - I only did it quickly to see if I could import into Revit,
I'll have to spend lot more time making sure mirrored components have tangent faces.
Message 13 of 21
info
I've tried reproducing the geometry in Revit, but I can't create working Sweep,
I've taken some screen shots which in sweep mode - so you can see the swept path & profile I'm trying to sweep.
Message 14 of 21
info
here are more images
Message 15 of 21
info
I realised there is a bug in the version of SW I'm running when converting to .RFA format.
I have to use the 2019 version to get a successful .RFA file which shows the model in Revit.
but there's a problem - when it does, the conversion tessellates all surfaces, which effects the presentation!
I've attached a surface I did in SW and exported as a .RFA
Message 16 of 21
Import it in AutoCAD and save as DWG, then import the DWG in Revit.
Message 17 of 21
info
That's great!
I've redone the model in SW (2019),
Can you do the same with my new attached model?
Also, if it's possible can you save in Revit 2020 or just save it as a DWG and send it to me?
Message 19 of 21
info
Thanks for the link, but I only have AutoCAD Lt.
Message 20 of 21
