Exported DWG Viewports too Small
10 ANTWORTEN 10
Nachricht 1 von 11
aflferraz
1677 Aufrufe, 10 Antworten
Hi there,
I'm having an issue that I can't figure it out what is going on.
My problem is that although I have a view in a Revit Sheet, the frame view is away from the actual limits of the graphical elements (print 1), after I export the te sheet to DWG/ Autocad, that same limit shrinks to much, it reduces to the grafical elements limits (print 2).
The DWG view port limits overlaps the drawing limits and some elements won't show/print (print 3).
At this point I need to edit/ enlarge the viewports limits in Autocad to be able to see/ print all drawing elements, and that is not at all very practical, to say the least.
I already try to lok for a solution but with no luck.
Thanks for any helping tip and time taken.
10 ANTWORTEN 10
Nachricht 2 von 11
Rafal.Gaweda
als Antwort auf: aflferraz
Hi @aflferraz
Have You tried the same on Revit 2020.2?
Can You post example Revit file?
Rafal Gaweda
Nachricht 3 von 11
aflferraz
My apologies for the misspelled title, I already asked for a correction.
The correct title is "Exported DWG Viewports are too Small"
Sorry
Nachricht 4 von 11
aflferraz
als Antwort auf: Rafal.Gaweda
Hi
Thanks for the reply, after you reply, I tried several scenarios and this was the result.
With 2018 I have no issues regarding this matter, I use other project, since I cannot downgrade from 2019 to 2018. That said, and with other project in the 2018 I have no issue.
As you request i also attached part of the REVIT model and the dwg exported file, where I point out in red the viewports with the issue.
Thanks for the time taken.
Nachricht 5 von 11
aflferraz
The Revit model from where I exported the dwg.
Nachricht 6 von 11
Rafal.Gaweda
Hi @aflferraz
Thank You for the files.
I have escalated issue to development team for further investigation.
Once I have any update from the development team I will keep you posted.
Rafal Gaweda
Nachricht 7 von 11
sandris.metlovs
Hi, is here any news on this issue really annoying go to all DWG files. Thanks. Please fix ASAP.
Nachricht 8 von 11
aflferraz
als Antwort auf: sandris.metlovs
Hi  sandris.metlovs
I'm sorry but I don't have or received any solution to this issue yet and yes it's really REALLY ANNOYING.
Thanks.
Nachricht 9 von 11
hmunsell
i'm using Revit 2020.2, i dont have 2018.
that said..... if you hover over the view on the Revit sheet, the dark box you see is Not the crop region it is just the view selection outline (sorry, don't know the official name). if you double click on the Revit view on the sheet, the "Crop Region" window is virtually identical to the View Port created in Autocad. The content on the sheets is the same size when i measured them.
Howard Munsell
Nachricht 10 von 11
aflferraz
als Antwort auf: hmunsell
Hi @
If I export the sheet to autocad the viewport is reduced\shrink to that limit (print 3_left).
I sorry if i missed understood you, I'm repeating myself but this is a very annoying issue.
Is something I'm missing here?
Thanks.
Nachricht 11 von 11
aflferraz
Although it's not the perfect solution, It's a simple workaround to avoid part of this issue.
What I did (in my case I'm using inserted dwg legends and on those drawings) I made an exterior limit with a non printable layer, to force the issue to adjust to that limit and not the elements I want to see\print (Print 1).
After export from Revit to Autocad and print the sheet it looks normal as it should (Print 2).
This is a simple workaround (don't know why didnt think this before), not the solution because if you look (print2) the axis identifier circle is cut precisely by this shrink issue.
