I exported a revit project to a 3d dwg so I could make it into a family. I chose the colors to be black and white and the amily looks fine. However, when I insert it into a project it becomes green. ?
when you exported the content from Revit, what platform did you export it to (AutoCAD)?
in the 3d dwg are there Layers, Layer names with colors and line weights assigned to them
are there materials, solids, hatches or filled regions in the 3d dwg after exporting?
what category or sub-category was assigned to the components, linework or masses.
are you using filters for these categories or sub-categories
Hi @Anonymous
Can you share the file to test?
Which versions of Revit and AutoCAD are you using? Can you confirm if you have the updates installed?
Can you check the graphics card compatibility using the tool on Autodesk Certified Hardware page
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
