Exported DWF "ORIGINAL SIZE" Not matching Revit Sheet size ?
4 ANTWORTEN 4
Nachricht 1 von 5
saf-a
454 Aufrufe, 4 Antworten
Hello
I have set up an A3 Size Sheet.
I want to Export it to DWF to print it from DWF Autodesk viewer app.
In DWF Export dialogue I use either "A3" or "Use sheet size" both give the same results in Autodesk Design Review as far as dwf "sheet size"
However, when going into the printing dialogue and trying to print to scale I get this weird difference:
Shouldn't this "Original size" match the A3 size? How can I achieve this when Exporting?
How can I export correctly from Revit in order to be able to print the DWF File to scale?
Hope someone helps out.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: saf-a
Are your sheets in Revit A3 or A1?
Nachricht 3 von 5
Lance.Coffey
Thank you for the question @saf-a!
I tried reproducing what you are seeing by exporting Sheet A101 – Site Plan from the rac_basic_sample_project.rvt and I am not seeing similar behavior.
The sheet was saved from Revit as A1 size (840 x 594mm), and remains A1 size when printed from Design Review.
Can you test this with the rac_basic_sample_project.rvt sample project and confirm if you see the same results?
Lance Coffey
Technical Support Specialist
Nachricht 4 von 5
saf-a
als Antwort auf: Lance.Coffey
Hello, I have attached the sheet file I'm using as an RFA
Is it truely A3? or have I missed something up while creating it?
Nachricht 5 von 5
It is an A3 titleblock so it is not a problem. Can you share your Revit print settings when you create the DWF?
