When I export the attached “sample” RVT file to DWF, the results are different from the PDF file!! This is 100+ sheets project and we usually review in DWF format and the final deliverable to client is PDF. any thoughts are appreciated.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Thanks for the reply, But how to alter font handling settings from Revit export?
Using same print drivers with AutoCAD , the PDF/DWF outputs are matching without having to change anything.
Use a narrow font and set the width factor from 0.8 back to 1.
Thanks both of you. This is our first project with Revit 2019 and we've never had this issue with Revit 2016.
Seems like we'll need to update 2019 template accordingly ![]()
All text in 2017 was changed. If you are upgrading from 2016 (or updating/opening projects) or older, it is recommended you check all text outputs for these projects as things may have changed.
Read the top paragraph of this article for additional information.
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-F57326A0-BCE1-44D6-A5FE-3F084258EE28
