Exported axos (not rendered) are not lining up
2 ANTWORTEN 2
Nachricht 1 von 3
295 Aufrufe, 2 Antworten
Hi! I am very new to all of this and hope someone can help me. I am trying to export PNGs of axonometric drawings that are intended to end up as a gif (starting from basement going up level by level to overview). I use the section box to choose where the drawing is cut.
I export all of the 'frames' at the same settings, but they do not end up lining up in the pictures. I.e. when I put all of them together in a video the drawing jumps around, and is often a different size. Even if I put them in PowerPoint and try to align the settings (size and position) they're different and I have no idea why.
They're all the same scale (1:10) and exported on the same settings (zoom to 100% of size, PNG, 300DPI).
I urgently need help please!!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Nachricht 3 von 3
syman2000
When you create the 3d you make have the crop view enable? If you want to make it consistent, you want to define it first before you use section box. That way when you export, it will keep the view crop relative to each other. If you don't do that, other program will cut off blank space and you will see the image export scale completely different.
