Export to PDF
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
7131 Aufrufe, 3 Antworten
Export to PDF
Revit fails to print PDF. When selecting the Sheets to print, the button "Select" doesn't work. It simply do not react at all, as if the computer is not responding, but everything is working! Do someone has same issue? I could use some help with that.
Viktorija
Tags (3)
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: Anonymous
Try to install latest updates from Autodesk and see if helps. Thanks
Nachricht 3 von 4
Do not use Microsoft Print to PDF as the Windows default printer.  Change to another one and restart Revit.
Nachricht 4 von 4
Viveka_CD
Hi @Anonymous
I see that you are a new visitor! Welcome to the Autodesk community! Smiley (fröhlich)
  • Please try the free PDF creator recommendations in a similar post HERE
  • Some of the PDF creators are Adobe PDF, CutePDF, PDF995
  • Also, try exporting to "dwf" and print to PDF if you still not able to print from Revit. Let us know how it goes.
  • We have reports where Print Command not functioning after Windows 10 Anniversary Update - See HERE for steps to resolve this issue
  • See HERE for information on unresponsive buttons in Print dialog when Microsoft Print to PDF is chosen
Please mark this response as "Accept as Solution" if it answers your question to help other members seeking similar solutions. Kudos gladly accepted.
Happy to help if you have additional questions!
