Export to dwg settings from a Revit 2019 project migrate back to Revit 2018
Message 1 of 11
How to migrate the "Export to dwg settings" from a Revit 2019 project back to Revit 2018.
Actually we made an office template using Revit 2019, but now another project comes and it requires revit 2018.
How do I migrate the template settings backwards?
Replies (10)
Message 2 of 11
Unfortunately you can't migrate backwards with Revit.  You won't be able to save your 2019 template as a 2018 file.
Message 3 of 11
is there any workaround?
i read there is a revit.ini file that stores all the export settings..
Message 4 of 11
I'm a bit confused.  Are you trying to migrate your template backwards, or export drawings?  You should be able to import drawings exported from Revit 2019 into Revit 2018.
Message 5 of 11
The CAD export settings is part of the template in 2019, which i need it now, in another project in 2018.
Aside from the export settings, all the other line styles/object style.. i guess i will have to rebuild them all is it correct?
Message 6 of 11
TripleM-Dev.net
Uhm, could be done with the Revit API (DWGExportOptions.GetExportLayerTable )
- Michel
Message 7 of 11
The Standards are just plain old text files. Just load the 2019 Standard into 2018.
….is this what you are talking about?
one more...
Message 8 of 11
Hi. Our office has customized the export settings. So it's different from the "standard"
Message 9 of 11
TripleM-Dev.net
In my addins I can review the DWG export setting, from this I can make a plain text export.
This plain text document could be used to import the layer settings (as described by @barthbradley )
Only the other settings like units, layermodifiers have to be manually edited (the import only contains the 'direct' layer setting).
Let me know if you're interested.
Below a screenshot of a DWG export Layer settings
Addin with Full list of DWG layer settingsAddin with Full list of DWG layer settings
- Michel
Message 10 of 11
Hi I am interested.
Message 11 of 11
TripleM-Dev.net
@Anonymous ,
If you can send me a Revit project/template file with the DwgExport Settings, I will create the import file from it.
You can do a Project Transfer of the DWG setting to a Empty (Basic) Revit template.
- Michel
