Export to DWG, layer overrides for walls cut with plan region
0 ANTWORTEN 0
Nachricht 1 von 1
carl
145 Aufrufe, 0 Antworten
Hi all,
I'm having trouble controlling the exported hatch color for my walls in a dwg export from a plan drawing. I want to use the "create new layer for overrides" in the dwg export settings. However, this also makes the hatches for exterior walls cut by a plan region to show in a different hatch color and a different layer than exterior walls not cut by a plan region, something I don't want.
Is there any way I can controll this behavior to either keep all exterior walls in the same layer (preferred option) or at least control the hatch color the stay the same as the non plan region affected walls.
Any hints would be appreciated!
Beschriftungen (5)
0 ANTWORTEN 0
