A while ago, I have posted a question on the correct way to bring survey into Revit model and acquire coordinates; Now I need to export the CAD file for civil engineer's use, I realized that first of all I should use True North for the view before export so they can get the correct orientation and won't need to rotate it. I thought Revit file has the right coordinate information after acquiring the coordinates, since the spot coordinates acquired is consistent with the one in CAD survey file; however, when I compare the CAD file I exported and the original survey file, I noticed there is difference. see below. How can I make sure the exported Cad file has the exact correct coordinate information? Thanks
- from survey cad file
- from exported cad file with survey
- from Revit model
