Hello Everyone:
I have this issue, i need to export all my Revit sheets, i have like 40, to a single Cad file. It is possible?
Regards
Gelöst! Gehe zur Lösung
Gelöst von GustavoUbriaco. Gehe zur Lösung
Hi, there are no way to combine all sheets, I sugget create a multisheet to export and the in AutoCad only configure one layout and then only use copy layout and adjust each view. I'ts a better way if you preffer a single file
create a multifamily sheet
Non select the xref option to not generate a lot of files.
configure the layout size
then right click on layout configured and then mark copy option
then only move each view to adjust
Gustavo Ubriaco Contreras
You're welcome!
