Export sheet to cad with different layout and model crop
1 ANTWORT 1
Nachricht 1 von 2
ravilaro
266 Aufrufe, 1 Antwort
Hello everyone,
I am exporting a revit sheet to CAD for a client, and I need it to show a portion of a floor plan only autocad "layout", but in autocad "model" I need to see the hole floor plan. Is this possible?
By the moment, all I can get is to crop the view and show it right on the Sheet, but if i want to see the hole floor plan when switching to MODEL in autocad I will see only the cropped portion aswell.
In other topic, but related, does anybody know how to show a CAD exported sheet with proyect north on autocad "layout" but true north on autocad "model"?
I know the plan is to not use autocad in the future, but it's the clients needs.
Thanks!
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: ravilaro
hi, revit export to dwg , work like all you see will be export
so if you are in sheet view he will export the title block and the crow view
and when you are in the view he will export the all view
so for you client you can export directly from the view plan and have the all plan
