(Export Setups Cad)How to map category name to layer name
Wuhao9527
Wuhao9527
I created some new lines for new subcategories. In DWG/DXF Export setup, The lines Layer are "{lines}"(as same layer as the Line's layer). How can I map category name to layer name.
emmanoelneri
I'm not sure if there is a automatic way to do that...  i would tell you to set it manualy and save the "Export template" to use it later
